Canon Powershot A610 Speaker Replacement
  1. Canon Powershot A610 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
    • Remove the side paneling from the camera.
    • Remove the two remaining screws attached to the frame of the camera.
  2. Canon Powershot A610 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the bottom panel of the camera.
  3. Canon Powershot A610 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery cover.
    • Remove the four screws inside.
    • One screw is located on the top side of the bottom cover. The remaining three screws are located at the bottom of the battery compartment.
    • Close the battery cover.
  4. Canon Powershot A610 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the "DIGITAL AV OUT" door on the camera.
    • Remove the three screws.
    • Remove the door from the camera.
  5. Canon Powershot A610 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gripping the sides of the top cover, gently pull apart the top cover from the camera.
    • The top cover does not completely detach.
  6. Canon Powershot A610 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull apart the front cover from the camera.
    • This may require some force. Be careful not to break the plastic.
  7. Canon Powershot A610 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool, push the black attachment away from the white connection piece to detach the connector ribbon.
  8. Canon Powershot A610 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 mm screw holding the metal frame.
  9. Canon Powershot A610 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an unfolded paper clip to push the speaker from the top of the casing out towards the bottom.
    • Use a bit of force as the speaker is glued into the top casing.
    • There is a soft fabric speaker cover separating the speaker from the casing. Make sure not to remove it from its position in the housing.
  10. Canon Powershot A610 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the speaker at the two solder points and reattach the new speaker.
Matthew Ramirez
crwdns2935283:001/20/11crwdne2935283:0
631 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-26, Maness Winter 2011 crwdns2935289:0Cal Poly, Team 11-26, Maness Winter 2011crwdne2935289:0
CPSU-MANESS-W11S11G26
crwdns2942667:0crwdne2942667:0 3,055
