Canon Powershot A610 Camera Housing Replacement
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement, Camera Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement, Camera Housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot A610 Camera Housing Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
Matthew Ramirez
crwdns2935283:001/20/11crwdne2935283:0
631 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-26, Maness Winter 2011 crwdns2935289:0Cal Poly, Team 11-26, Maness Winter 2011crwdne2935289:0
CPSU-MANESS-W11S11G26
crwdns2942667:0crwdne2942667:0 9,527
