Canon PowerShot SX600 HS camera, can have a broken or damaged Power and Shutter Button. Problems with the Power and Shutter Button may prevent the camera from turning on or functioning properly. Use this guide when replacing the Power and Shutter Button.
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Depress the orange lever holding the battery in place to unlock it.
Use your fingers to remove the battery.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
Use an opening tool to gently remove the power and shutter button assembly from the frame.
Where does one buy an “opening tool”?
Where does one buy an “opening tool?”
Hello Evelyn,
you can buy it in the ifixit store. Otherwise you can use a plastic card you don’t need any more (it will be scratched and or bend afterwards, so you probably better don take a creditcard).
