Canon PowerShot SX520 HS Lens Replacement
    1. Canon PowerShot SX520 HS Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, slide the battery compartment door to the right until it unlocks.
    2. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the door along hinges to open.
      • Take out the battery with your fingers.
    1. Canon PowerShot SX520 HS Lens Replacement, Back Face: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX520 HS Lens Replacement, Back Face: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX520 HS Lens Replacement, Back Face: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
    2. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
    3. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull back the rubber facing to access the A/V and HDMI output compartment.
      • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
    4. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once all screws are removed, pull the back facing off with your fingers.
    1. Canon PowerShot SX520 HS Lens Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
    2. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pop out the LCD screen with your fingers.
    1. Canon PowerShot SX520 HS Lens Replacement, Metal Plate: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX520 HS Lens Replacement, Metal Plate: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
      • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
      • After all 8 screws are removed, pull the metal plate out with your fingers.
    1. Canon PowerShot SX520 HS Lens Replacement, Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unlcip the large cable by pulling up on the metal part with your finger.
      • Slide out the 2 smaller cables with your fingers.
    2. Canon PowerShot SX520 HS Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the lens by grabbing the sides with your fingers.
Lisa Choe
crwdns2935283:009/22/15crwdne2935283:0
460 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-4, Williams Fall 2015 crwdns2935289:0Baylor, Team 4-4, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S4G4
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
SimoneGallina - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 3,951
