Canon PowerShot SX50 HS Flash Bulb Replacement
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery compartment on the bottom of the camera.
      • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
      • Now remove the battery pack from the camera with your fingers.
    1. Canon PowerShot SX50 HS Flash Bulb Replacement, Flash Bulb: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the flash as you would when using and activating the flash.
    2. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two Phillips #000 screws, length 3 mm, on both sides of the flash.
    3. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull off the back encasement of the flash with your fingers. The internals will now become visible.
    4. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the black, white and the beige wires. Desolder these wires at the point of connection with the bulb.
      • See the guide on this link for soldering and desoldering.
    5. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the wires have been desoldered, pull the flash out of its casing.
      • Remove one end of the rubber band holding the bulb in place.
      • Slide the bulb out of the flash.
    6. Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX50 HS Flash Bulb Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Completely remove the rubber band from the flash bulb.
Daniel Gurrola
crwdns2935283:004/01/15crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-7, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 12-7, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S12G7
crwdns2935297:084crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hello! excellent explanation . Thank you very much! I have a question : could you tell me where I can buy the replacement lamp ? I already tried searching online but can not find anywhere that sells it. Thank you very much , greetings !
German Witt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need a bulb, no one can tell where you can find a bulb, and it says no parts needed. that's stupid since you need a replacement bulb that you can't find. without it all this is useless.
buborek1974 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i found the replacement bulb???Why it is written that there is no need for replacement parts?
Audrey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you know where I can purchase a bulb to go with this type of camera? I can not find just the bulb. Please HELP!
arusso4e - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 6,734
