Canon PowerShot SX260 HS Motherboard Replacement
  1. Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX260 HS Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • *Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • There are a total of 6 (3mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • 1.) Remove the 2 screws on the left side
    • 2.) Remove the 2 screws on the bottom of the camera.
    • 3.) Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spludger tool or small flathead screw driver to gently lift and remove back face plate.
  3. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing exterior screws, gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the front faceplate you will find 4 (3mm) screws on the interior.
    • Remove all 4 interior screws.
  5. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 1 (6 mm) Screw from the bottom of the silver metal plate. The screw is also silver
  6. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With blue spludger tool gently lift the metal plate from the face of the camera.
    • The plate is held by a piece of double sided tape so there will be a bit of resistance.
  7. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 3 (3 mm) screws from the top surface of the motherboard.
    • You will notice that there is one on the top, and 2 on the bottom in a triangular shape.
  8. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the ribbon cable from the top of the motherboard with a pair of tweezers.
    • Be careful during this step not to rip or tear the cable.
  9. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the blue spludger tool to gently unplug the last ribbon cable that is attached to the motherboard.
  10. Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX260 HS Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard with your fingers.
Tyler Kelch
crwdns2935283:003/05/15crwdne2935283:0
622 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 11-8, Blackburne Winter 2015 crwdns2935289:0Sam Houston State, Team 11-8, Blackburne Winter 2015crwdne2935289:0
SHSU-BLACKBURNE-W15S11G8
Where is the internal clock/calendar battery located?
GPa Rocks - crwdns2934203:0crwdne2934203:0
Internal clock battery is under circuit board on right side of lens as seen in photo for Step 9. See 2:48 - 3:19 in this video: https://www.youtube.com/watch?v=Awmm6hDm....
Paul Unger - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,549
