Canon PowerShot SX170 IS Disassembly
  1. Canon PowerShot SX170 IS Disassembly, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws that secure the back panel using a Phillips screwdriver.
    • Remove screws on the bottom, left and right sides of the camera using a Phillips screwdriver.
    • Pull back the rubber facing to access the screw.
  2. Canon PowerShot SX170 IS Disassembly, Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all screws are removed, open up the back case with a plastic opener from the left side.
  3. Canon PowerShot SX170 IS Disassembly, Function Wheel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Function Wheel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Function Wheel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws that secure the small metal plate using a Phillips screwdriver.
    • Gently flip up the flex ribbon lock and remove the flex ribbon.
  4. Canon PowerShot SX170 IS Disassembly, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the screen to the left.
  5. Canon PowerShot SX170 IS Disassembly, Front Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Front Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. Canon PowerShot SX170 IS Disassembly, Front Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Front Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Front Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws below the flash and on the left sides of the camera using a Phillips screwdriver.
    • Leave the flash unfolded.
    • Pull the front case forward.
  7. Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all marked screws using a Phillips screwdriver.
    • Remove the small metal part.
  8. Canon PowerShot SX170 IS Disassembly, Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Cable: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the microphone.
    • Remove the flex ribbon.
    • Remove the flash switch.
  9. Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Metal Frame: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw using a Phillips screwdriver.
    • Lift the flash a little to remove the metal frame.
  10. Canon PowerShot SX170 IS Disassembly, Lens Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens Cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens Cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  11. Canon PowerShot SX170 IS Disassembly, Lens Cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens Cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove flex ribbon and light sensor.
  12. Canon PowerShot SX170 IS Disassembly, Lens Screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens Screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens Screws: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws using a Phillips screwdriver.
    • Lift up the back case.
  13. Canon PowerShot SX170 IS Disassembly, Lens and Sensor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX170 IS Disassembly, Lens and Sensor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you can clean the lens.
JockiToru
crwdns2935283:012/30/20crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Hello JockiToru! Thanks for the guide.
I took the liberty to correct 'lense' to 'lens'... You can have many lenses, but only one lens!
Also 'bellow' is an air pumping device. I suspect you meant 'lower', so the word is 'below'.
Again, thanks and I will be testing you disassembly, as there seems to be an annoying small insect in my camera.
Jon - crwdns2934203:0crwdne2934203:0
Hello Jon,
thank you very much for your feedback. I hope you were able to remove that insect.
JockiToru -
Thank you for the guide! my SX170 is taking shots properly again, had to clean the lens after it was kept for a long time, it saved me the cost to bring it to a shop to have it cleaned.
Benedick Brian Cartera - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,084
