This guide provides a breakdown that shows how to replace the function wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the function wheel.
Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
Using your hands, gently separate the back panel from the camera.
Continue to pull the back panel until it completely detaches from the camera.
Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
Remove and replace the function wheel.
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
