Canon PowerShot SX150 IS Digital Image Sensor Replacement
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the battery cover on the bottom of the camera.
      • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
      • Remove batteries.
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 2mm screws above the screen using the size J000 screwdriver.
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
      • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
    3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
    4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic panel surrounding the back screen.
    5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 3mm screws using the size J000 screw driver from the button plate.
      • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
      • Move the button plate out of the way.
    6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
      • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
      • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
    7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
      • You can then lift the screen out of place and set it aside.
    8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
      • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
      • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
    9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently detach the flex ribbon with your tweezers before removing the front plate.
    10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
      • Remove the two 5mm screws.
      • Remove the one 3 mm screw.
      • Using the same screwdriver, remove the 3mm screw from the top of the camera.
      • Pull the panel off and set it aside.
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the two flex ribbons with your tweezers and remove them.
      • Move the circuit board to the side.
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SX150 IS Digital Image Sensor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three 2 mm screws from around the sensor.
      • Pull the sensor away.
Avery Hyde
crwdns2935283:009/12/16crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Fall 2016 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Fall 2016crwdne2935289:0
WCU-VIRTUE-F16S1G1
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 104
crwdns2942667:0crwdne2942667:0 1,595
