Disassemble the back cover of the Canon PowerShot SX120 IS in order to open the camera and access the inside components.
Turning the camera so the screen is facing you.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
Open the DC IN A/V OUT DIGITAL cover.
Turn the camera with the lens facing down.
Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
