Canon PowerShot SD700 LCD screen Replacement
    1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the camera by pressing the power button above the LCD screen.
    2. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
    3. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
    4. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
    5. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
      • This screw will be longer than the rest of the screws.
    6. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the front, back, and side casings from the camera and set to the side.
    1. Canon PowerShot SD700 LCD screen Replacement, LCD screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws that connect the LCD and backlight to the main body of the camera.
    2. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pry the LCD and the backlight from the main body of the camera.
      • Gently pry the LCD from the backlight.
      • The thin ribbon cable is for the backlight.
      • The thick ribbon cable is for the LCD screen.
    3. Canon PowerShot SD700 LCD screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the ZIF connector that covers the thick ribbon cable.
      • This ZIF connector is fragile. Use caution when lifting it from its down position.
      • Insert the new LCD and reassemble the camera.
Emilio Rossi
crwdns2935283:004/07/11crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-71, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-71, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G71
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 3,104
