Canon PowerShot SD700 E18 Error Replacement
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front, back, and side casings from the camera and set to the side.
  7. crwdns2935267:0crwdne2935267:0
    Dust Blower
    $5.99
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
To reassemble your device, follow steps 1-6 instructions in reverse order.
Aaron Lee
crwdns2935283:004/07/11crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-71, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-71, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G71
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 3,550
