Canon PowerShot SD700 Backlight Replacement
  1. Canon PowerShot SD700 Backlight Replacement, Outside Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Backlight Replacement, LCD screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD700 Backlight Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD700 Backlight Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 Backlight Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
  10. Canon PowerShot SD700 Backlight Replacement, Backlight: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the ribbon from the housing on the circuitry.
    • Take the new ribbon and insert it into the housing.
    • Tweezers or a tool with a sharp point can be used.
Emilio Rossi
crwdns2935283:004/07/11crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-71, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-71, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G71
crwdns2942667:0crwdne2942667:0 1,733
