Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement
  1. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Front and Rear Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Wrist Strap Mount: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two Phillips screws using a #00 Phillips screwdriver from front cover of the camera.
  11. Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD500 Digital ELPH Wrist Strap Mount Replacement, Remove Mount: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove plastic cover from front side of camera.
    • Remove and pull away wrist strap mount from the front side of the camera.
Kimberly Saeger
crwdns2935283:010/13/14crwdne2935283:0
Clemson, Team 2-1, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-1, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G1
crwdns2942667:0crwdne2942667:0 337
