Canon PowerShot SD500 Digital ELPH LCD Replacement
  1. Canon PowerShot SD500 Digital ELPH LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement, Front and Rear Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH LCD Replacement, Button Contact Panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH LCD Replacement, LCD: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD500 Digital ELPH LCD Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
Taylor Shields
crwdns2935283:010/13/14crwdne2935283:0
846 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-1, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-1, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G1
crwdns2942667:0crwdne2942667:0 912
