USB Port can be damaged from force exertion on the pins which can prevent it to connect to an external device. This guide will show the steps to replace the USB port in the device.
Remove the four 2mm Phillips #00 screws on both sides of the camera.
Remove the single 4mm Phillips #00 screw from the bottom.
Remove the front face panel off of the camera.
Remove the 3mm Phillips #000 screw from the top of the camera.
Pry the golden ribbon cable from the motherboard with a plastic opening tool.
Remove the 3mm Phillips #000 screw from the motherboard.
Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Unplug the small chip from the face of the camera using a pair of tweezers.
Remove the 3mm Phillips #000 screw from the rear face of the camera.
Remove the top panel from the camera.
Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
Remove the 3mm Phillips #000 screw located at the top right of the USB port.
