The motherboard can be damaged because of overheat and a short circuit which can cause the camera to stop working. This guide will show how to replace the motherboard in the device.
Remove two 2mm Phillips #00 screws on both sides of the camera.
Remove the 4mm Phillips #000 screw from the bottom.
Remove the front face panel of the camera.
Remove the rear panel of the camera by using hand with firm pressure.
Remove the 3mm Phillips #000 screw from the top of the camera.
Pry the three golden ribbons off the motherboard using a plastic opening tool.
Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
Once released, the small black tab will point straight away from the front face of the camera and the golden film will no longer be attached to the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Unplug the small chip from the face of the camera using a pair of tweezers.
Remove the three 3mm Phillips #000 screws from the motherboard.
Remove the 3mm Phillips #000 screw from the rear face of the camera.
Remove the top panel from the camera.
