This guide will show you how to properly replace a faulty shutter button.
Remove the two 2mm J00 screws on the right exterior.
Remove a single 4 mm J00 on the bottom exterior.
Remove a single 3mm J00 on the left exterior.
Once the front shell of the camera is removed the back shell should slide off just the same.
crwdns2935267:0crwdne2935267:0Heavy-Duty Spudger$4.99
Use your Heavy-Duty Spudger to remove your faulty shutter piece.
Insert Heavy-Duty Spudger under shutter button to release shutter button.
