Canon PowerShot SD1300 IS Flash Assembly Replacement
  1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
  2. Canon PowerShot SD1300 IS Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove a 3mm J00 screw from behind wires under the flash.
  4. Canon PowerShot SD1300 IS Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use plastic opening tool to remove the screen to gain access to the screws to remove the Flash Assembly.
  5. Canon PowerShot SD1300 IS Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm J00 screws under the screen.
    • Remove the 4mm J00 screws under the screen.
    • The flash assembly is now released and should be able to be removed from the front side of the camera.
Clayton
crwdns2935283:003/20/17crwdne2935283:0
584 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S13-G1, Bennett Spring 2017 crwdns2935289:0Texas Tech, Team S13-G1, Bennett Spring 2017crwdne2935289:0
TTU-BENNETT-S17S13G1
crwdns2942667:0crwdne2942667:0 514
