Canon PowerShot SD1200 IS Lens Assembly Replacement
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Front and Rear Covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery.
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
      • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
      • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull off the front cover.
      • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
      • Remove the back cover.
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement, LCD: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
      • Slide out the ribbon cable using fingers or tweezers.
      • Be sure you are prying up on the hinged retaining flap, not the connector.
      • Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
      • The Brackets have tabs that need to be pried up.
      • Remove the screw below the shutter button. (2.5mm Phillips 00)
      • Holding the sides of the LCD screen, lift the screen up and away to remove.
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot SD1200 IS Lens Assembly Replacement, Flash Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
      • Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws (2 mm Phillips 00) along the back edge of the camera frame directly behind the flash assembly.
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift out the flash assembly.
    1. Canon PowerShot SD1200 IS Lens Assembly Replacement, Lens Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger to gently pry up both sides of the flat-topped connector, then lift the cable directly up out of its socket.
    2. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 corner screws on the back of the camera in silver metal frame surrounding the back of the lens assembly (2.5 mm Phillips 00) .
    3. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger to gently lift out the LED at the top of the lens assembly.
    4. Canon PowerShot SD1200 IS Lens Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the lens assembly.
crwdns2935229:05crwdne2935229:0
Jeff Casper
crwdns2935283:009/15/16crwdne2935283:0
897 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-5, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-5, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G5
crwdns2935297:056crwdne2935297:0
i have this same camera, and for me all the sudden it stopped focasing completely. everything else works, and it isnt in any weird modes. when i try to focas especially on auto focas with the half button push, i hear some abnormal clicking like it is trying to auto focas but cant. im not sure what to do!
Katelyn Lehmann - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same problem after my camera sat unused for a year. Everything functions fine except the camera will not focus.
ROGER - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 142
crwdns2942667:0crwdne2942667:0 4,522
