Use this guide to replace the front and back covers of the Canon PowerShot SD1200 IS camera or to access damaged internal components.
            Remove the battery.
            Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
            Remove the two screws from the bottom of the camera. (4mm Phillips 00)
            Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
            Pull off the front cover.
            Remove the back cover.
