Use this guide to access or replace the flash assembly on your Canon Powershot SD1200 IS camera.
            Remove the battery.
            Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
            Remove the two screws from the bottom of the camera. (4mm Phillips 00)
            Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
            Pull off the front cover.
            Remove the back cover.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
            Slide out the ribbon cable using fingers or tweezers.
            Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
            Remove the L shaped brackets from the left and right side of the LCD screen with the spudger tool.
            Remove the screw below the shutter button. (2.5mm Phillips 00)
            Holding the sides of the LCD screen, lift the screen up and away to remove.
            Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
            Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
            Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
            Remove the two screws (2 mm Phillips 00) along the back edge of the camera frame directly behind the flash assembly.
