Canon PowerShot S80 Motherboard Replacement
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S80 Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the motherboard from the camera.
BrettH
crwdns2935283:010/28/09crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-5, Maness SU 2012 crwdns2935289:0Cal Poly, Team 19-5, Maness SU 2012crwdne2935289:0
CPSU-MANESS-SU12S19G5
crwdns2942667:0crwdne2942667:0 4,609
