Canon PowerShot S500 AV Port Replacement
    1. Canon PowerShot S500 AV Port Replacement, Front and Rear Casing : crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement, Front and Rear Casing : crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
    2. Canon PowerShot S500 AV Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
    3. Canon PowerShot S500 AV Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
    4. Canon PowerShot S500 AV Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
    5. Canon PowerShot S500 AV Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
    1. Canon PowerShot S500 AV Port Replacement, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
    2. Canon PowerShot S500 AV Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
    3. Canon PowerShot S500 AV Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
    4. Canon PowerShot S500 AV Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
    5. Canon PowerShot S500 AV Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
    6. Canon PowerShot S500 AV Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
    7. Canon PowerShot S500 AV Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Free this ribbon and the bottom panel from the rest of the camera.
    8. Canon PowerShot S500 AV Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
    9. Canon PowerShot S500 AV Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the blue ribbon gate using the Spudger.
    10. Canon PowerShot S500 AV Port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
    11. Canon PowerShot S500 AV Port Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the LCD away from the rest of the camera.
    1. Canon PowerShot S500 AV Port Replacement, Logic Board: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement, Logic Board: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift off the capture button by wiggling it back and forth while pulling upward.
      • Be careful not to damage the two clips.
    2. Canon PowerShot S500 AV Port Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip open the four ribbon gates using the Spudger.
      • Gently pull out the ribbon cables from the gates using the Spudger.
    3. Canon PowerShot S500 AV Port Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
    4. Canon PowerShot S500 AV Port Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift the logic board.
      • Be careful not to pull too hard and damage the white ribbon cable.
      • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
      • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
    5. Canon PowerShot S500 AV Port Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the logic board back down so that it is resting on the body of the camera.
      • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
    6. Canon PowerShot S500 AV Port Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
      • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
      • Desolder the two soldered ribbon cables attached to the logic board.
    7. Canon PowerShot S500 AV Port Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Free the logic board from the rest of the camera.
    1. Canon PowerShot S500 AV Port Replacement, AV Port: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pick up the Logic Board
    2. Canon PowerShot S500 AV Port Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S500 AV Port Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Blow the Particles out of the AV Port or USB Port using compressed air.
      • If the pins are damaged or missing, flip over the logic board and desolder the component from the logic board.
Nathan Balcom
crwdns2935283:001/21/10crwdne2935283:0
102 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-28, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 16-28, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S16G28
crwdns2942667:0crwdne2942667:0 3,494
