Use this guide to remove the motherboard on the right side of the camera.
Place camera LCD side up and press up on the battery door.
Let it swing open until you can see the battery inside.
Press down on the orange plastic.
This will gently eject the battery from its compartment.
Holding the edges, slide out the battery.
Look at the camera from the side with the lanyard and 4 screws.
Remove the two 3.4 mm screws on the metallic colored part.
Remove the 3mm screw on the top left.
Now remove the 5.3mm screw on the bottom.
Place the camera LCD side down.
Remove the two 5.3mm screws by the battery door.
Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
Stand the camera back up.
Remove the two 3.6mm screws on the side with the A/V Out port.
Lift open the rubber flap covering the A/V Out port.
Remove the 3.4mm screw in the center.
Use a spudger and gently open up the front panel of the camera.
There will be a brown plastic piece keeping the thin plastic ribbon in place.
Use the spudger to pull out the brown plastic piece attached to the orange plastic.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers and remove the metal piece inside the camera.
Disconnect the two plastic ribbons on the lower half of the right motherboard.
Remove the two 3.4mm screws on the right motherboard.
Disconnect the two wired plugs below the flash.
Disconnect the wired plug at the bottom of the right motherboard.
Use a pair of tweezers to pull the right motherboard away from the main body of the camera.
