Canon PowerShot S50 Left Motherboard Replacement
    1. Canon PowerShot S50 Left Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S50 Left Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
    2. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
    3. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Holding the edges, slide out the battery.
    1. Canon PowerShot S50 Left Motherboard Replacement, Front Panel/Battery Door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
    2. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
    3. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
    4. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
    5. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
    6. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
    7. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
    8. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
    9. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a pair of tweezers and remove the metal piece inside the camera.
    10. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
    1. Canon PowerShot S50 Left Motherboard Replacement, Left Motherboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the black and red cable on the left side of the lens.
    2. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the two orange ribbons on the front of the mother board.
    3. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull off the orange ribbon on the upper left of the motherboard.
      • This will become available only after removing the ribbon on top.
      • Remove the other two orange ribbons on the middle of the left motherboard.
    4. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
      • Go under the piece of plastic and remove the 2.6mm screw.
    5. Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S50 Left Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the top part of the left motherboard.
      • Gently lift the left motherboard up to remove
Jacob
crwdns2935283:003/29/12crwdne2935283:0
16 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-34, Maness Spring 2012 crwdns2935289:0Cal Poly, Team 7-34, Maness Spring 2012crwdne2935289:0
CPSU-MANESS-S12S7G34
crwdns2942667:0crwdne2942667:0 1,667
