We will be teaching how to replace the screen on a Canon PowerShot S230.
Unscrewing the small screws to take off the backing, screws are on the side and there are 4
Pry open the backing
Look for all screws before moving on
Remove metal shield from camera
It's fine if you just use your hands
Pry off the the front casing
REMOVE ALL SCREWS BEFORE MOVING ON
Remove screws and metal shield at the bottom of the camera
Remove the screen, also remove any screws that may get in the way, if the screen pops out it’s okay, it’s suppose to do that. Remove the screw at the bottom
Remove the highlighted screws to remove the copper facing
Now that the screen is replaced, all you need to do is go through the steps in reverse!
