Canon PowerShot S100 Top Panel Replacement
  1. Canon PowerShot S100 Top Panel Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement, Outer Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement, Outer Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Top Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Top Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Top Panel Replacement, Top Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 Top Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 Top Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot S100 Top Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
Ricky
crwdns2935283:002/23/15crwdne2935283:0
975 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 1-4, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S1G4
Ricky hi please I need some help! I repaired the screen but now the flash will not turn on! When I press the button the flash on the screen still says it is not on, and the flash itself will not pop out! What do I do!
Emily - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,468
