Canon PowerShot G7X Lens Replacement
  1. Canon PowerShot G7X Lens Replacement, Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back plate.
  6. Canon PowerShot G7X Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Lens Replacement, Flash: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement, Flash: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Lens Replacement, Lens: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Lens Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Lens Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Lens Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot G7X Lens Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
Kyle Pellham
crwdns2935283:004/09/18crwdne2935283:0
420 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G3, Carnegie Spring 2018 crwdns2935289:0Eastern Washington University, Team S1-G3, Carnegie Spring 2018crwdne2935289:0
EWU-CARNEGIE-S18S1G3
Not that great of step by step. Lots of missed steps and lots different screw length and thread. Over all it's just an ok guide.
Nick Thomas - crwdns2934203:0crwdne2934203:0
how do you tell if the lens is CCD or not
kingwayne77none - crwdns2934203:0crwdne2934203:0
Poor instructions indeed. At step 11 silver plate still stuck. More screws than indicated.
Hugo Lyppens - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 7,996
