Replacing the screen on a Canon PowerShot G3 is a process that takes a few steps, but are all simple. If the screen is cracked, displaying odd images, or will not turn on, it will need to be replaced. No special skills are required to replace the screen, but keep in mind attention to detail and a gentle hand are important. Follow this guide to replace the screen of a Canon Powershot G3.
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Open the screen.
Remove the Phillips #0 screws on the end of the screen.
Remove both Phillips #0 screws on the opposite side of the screen, located near the hinge.
Remove the back panel of the screen, using a spudger or opening tool if necessary.
Remove both Phillips #0 screws at the top of the screen.
Turn the screen perpendicular to body of the camera.
Remove the Phillips #0 screw at the base of the hinge.
Push the screen down and away from the camera.
Remove the single Phillips #0 screw at the base of the rotating arm. This will allow you to remove the screen cover.
Remove the black bar attached to the data ribbon cable. You will use this with the replacement.
Slide the black bar from underneath the white socket.
Insert the ribbon into the white socket.
Place the screen with monitor side out.
Repeat Steps 1-7 in reverse order to reassemble.
Great instructions but where can I find a new screen? Canon doesn't carry them any more.
I'm guessing that the screen is OK and the wiring/connections is the problem.
