Canon PowerShot G12 LCD Screen Replacement
  1. Canon PowerShot G12 LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the LCD screen from its locked position so the screen is visible.
  2. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the LCD screen perpendicular to the camera exposing the side screws.
    • Using a Phillips-head 00 screwdriver, unscrew the screws on both sides of the LCD screen.
  3. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front plate which states the Canon brand by prying open the side farthest from the camera simply with your fingers.
    • The circuit and internal wires will be exposed.
  4. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the LCD screen vertically and remove the final screws on the outer edge of the screen with the same Phillips-head 00 screwdriver. All screws have Loctite (blue) on them so they a difficult to turn. Make sure your Phillips screw driver fits perfectly. Sometimes a new screwdriver will need to have the tip filed down a little to fit.
    • The internal mechanisms will become loose and be able to be taken out.
  5. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, remove the external shell of the LCD screen leaving only the metal internal circuit board and screen attached.
  6. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of precision tweezers, carefully remove the yellow circuit connector from the port on the green circuit board.
    • Pull the yellow circuit connector down removing the screen from the metal shell.
  7. Canon PowerShot G12 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new LCD screen into the metal shell with the yellow connector tab facing outward.
    • Connect the new screen with the green circuit board ensuring you use the tweezers to connect it fully into the port.
Nathan Meuwissen
crwdns2935283:002/23/15crwdne2935283:0
552 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 1-5, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S1G5
ATTENTION
Connector of cable between camera and lcd board can be fit up or down side
Mark it before disconnect
Dufour - crwdns2934203:0crwdne2934203:0
Hello!
I wanted to change the screen but it seems that camera screen differ from each other according to the country where you bought it has anyone any piece of advice ?
I bought it in Singapore but live in Europe and I’m afraid to waist money buying a European one!
Chloe a - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 8,620
