Replacing the Canon-PowerShot G12 HDMI port is a highly-invasive step-intensive process that becomes necessary if the HDMI port sustains damage due to a crack, water, or jams, or if the HDMI port no longer functions properly.
In this guide, you will learn how to replace the HDMI port carefully without damaging any essential internal components.
            Open the back cover of the camera, see steps 1-6 in Canon PowerShot G12 Rear Function Setting Dial Replacement
            On the right side of the camera looking from the back, locate the HDMI port and use a spudger to remove it.
            Insert the new HDMI port until you hear a click on both sides, ensuring the holes match up with the ports on the camera.
The title of this guide suggests it gives instructions on replacing the HDMI port. In fact, it is a guide for the replacement of the HDMI port cover only.
