If the LCD screen of your Canon PowerShot G11 LCD is cracked or has stopped working you will need to replace it.
Remove the two 3.10mm Phillips #00 screws from the LCD case.
Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
Remove the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
Remove the 3.10mm Philips #00 screw.
Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
Remove the 2.22mm Phillips #00 screw that is located next to the indent handle.
Once the back panel is off remove the two 3.13mm Philips #00 screws.
On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and remove the 2.22mm Phillips #00 screw.
Remove the screen from the base of the LCD.
Do not remove this wire, it is not needed when replacing the screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to lift the small brown plastic snap before you remove the wire.
Did this. The first time i put it ack together it did not work , Had totake apart and adjust wires okay after put bake together again.
Jim Murphy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Followed these instructions and the result is excellent. Well done, and thanks very much. Saved me buying another camera!
Steve Rayner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do you get a new screen on there?
Jacob Fields - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Faltan planos. Por arte de magia el lcd aparece a la izquierda de varias fotos cuando debería estar debajo de la placa verde. Perdonen, muy mal explicado.
jlmgbaquero007 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
