Use this guide to replace the Canon PowerShot A75's batteries.
Turn the camera over and locate the "BATT OPEN" sliding switch.
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
