Canon PowerShot A620 Shutter Button Replacement
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Side Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Side Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Front Panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Back Panel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The trigger button will fall off once the screws have been removed.
Jaime Abraham
crwdns2935283:009/08/14crwdne2935283:0
350 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-1, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 1-1, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S1G1
crwdns2942667:0crwdne2942667:0 1,478
