Unscrew the three Phillips #00 1.6x3mm screws on the side.
Lift loose panel from the case.
Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
Open the battery door.
Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
Lift the terminal cover on the side of the camera.
Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
Gently pull the top panel to separate it from the case.
Gently pull the front panel to separate it from the camera.
Gently pull the terminal cover to separate it from the camera.
Slide the memory card cover down.
Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
Gently pull the back panel to separate it from the camera.
Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
Gently lift the metal plate and move it to the side.
Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
The trigger button will fall off once the screws have been removed.
