Canon PowerShot A460 Front Lens Replacement
    1. Canon PowerShot A460 Front Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
      • While still holding the switch, pull the cover down, allowing it to release and open.
    2. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tilt the camera slightly to allow the batteries to fall out.
    3. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press on and release the memory card to eject it.
    1. Canon PowerShot A460 Front Lens Replacement, Front Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
      • Make sure to keep the different size screws organized to make reassembling the camera simpler.
    2. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
    3. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
    4. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
    5. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the second battery cover on the bottom of camera.
      • Take the silver battery out of the camera.
    6. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
      • Remove the light grey, plastic piece.
      • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
    7. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slightly pull on each side of the camera. It should loosen up and come apart.
      • If it does not pull apart right away, use a little more force.
      • Do not give up!
    1. Canon PowerShot A460 Front Lens Replacement, Back Casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back case of the camera by pulling from the top.
      • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
    1. Canon PowerShot A460 Front Lens Replacement, LCD Screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4mm Phillips #00 screw from above the ribbon.
    2. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently peel off the blue tape on the top of the LCD screen.
    3. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
    4. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
    5. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
    6. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Since the tabs have been lifted, the ribbon should now slide out out easily.
      • Be careful not to distort the ribbon in any way.
    1. Canon PowerShot A460 Front Lens Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
    2. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
      • Detach the black piece that the screws previously held in place.
    3. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
    4. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
    5. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw that is located on the top of camera.
    6. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
      • Be careful not to damage the multiple adjacent orange ribbons.
    7. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
    8. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
      • Once unlocked, slide out the ribbon.
    9. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
    10. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
    1. Canon PowerShot A460 Front Lens Replacement, Front Lens: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six 2mm Phillips #00 screws that are located under the motherboard.
    2. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A460 Front Lens Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
      • The lens piece can now be removed from the camera.
    3. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5mm Phillips #00 screw on the back of the lens piece.
    4. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 2mm Phillips #00 screw on the bottom of the lens piece.
    5. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 2mm Phillips #00 screws on the top of the lens piece.
    6. Canon PowerShot A460 Front Lens Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently slide off the black piece surrounding the lens. The lens is now disassembled!
Tanner Coleman
crwdns2935283:001/18/13crwdne2935283:0
61 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-42, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-42, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G42
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
Gaby - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 5,677
