This guide will guide the user toward removing the front casing of a Canon PowerShot A460 to prepare the camera for future repairs.
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Tilt the camera slightly to allow the batteries to fall out.
Press on and release the memory card to eject it.
Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Remove the second battery cover on the bottom of camera.
Take the silver battery out of the camera.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
