Canon PowerShot A4000 IS Flash Replacement
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A4000 IS Flash Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Ansley Gardner
crwdns2935283:010/13/14crwdne2935283:0
761 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-3, Benson Fall 2014 crwdns2935289:0Clemson, Team 1-3, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S1G3
crwdns2935297:017crwdne2935297:0
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,899
