            Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
            Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
            Use the spudger tool to gently lever the front cover off.
            Your flash should come out very easily if you use your spudger to lever it out carefully.
            Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
