Canon PowerShot A3400 IS Flash Assembly Replacement
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place thumb on area right next to where it says open and slide to the right to open.
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the camera on to the side that has the image stabilizer label.
      • Remove the 5.00 mm screws that are on this side using the screwdriver.
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place camera on to the side with the A/V Out Digital Cover facing up.
      • Remove this visible 5.00 mm screw.
      • Pull the A/V Out Digital cover back to uncover the next step.
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5.00 mm screw from behind the cover.
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the battery cover is open.
    6. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the camera onto the side with the A/V out Digital cover.
      • Use your finger to pull this tab to the right.
    7. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the lens side by using your fingers or a spudger to pry it gently open.
      • Try to pry it loose all around that side so that it is easier to pull off.
    8. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your fingers, pull the screen side gently off.
      • Try to loosen it all around that side so that it is easier to try and pull it off.
    1. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 5 mm screws
    2. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screen by pulling at the two points as shown.
    3. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the metal plate with the plastic opening tool.
    4. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 5 mm screw
    5. Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon PowerShot A3400 IS Flash Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull the flash assembly away.
Emily Pretorius
crwdns2935283:001/13/15crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
easy to take off but waste of putting it back together..
The Heat - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 991
