This guide will walk the reader through the process of removing the front cover in order to replace it. There are no prerequisite guides that need to completed in order to remove the front cover.
Open the A/V Out Digital port cover on the function button side to reveal a screw.
Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
Gently lift the bottom of the front cover to roughly a 30 degree angle.
Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
Are the screws really hard to remove, or is it just me?
