This guide will walk the user through the removal of the back cover for the purpose of replacement. In order to remove the back cover of the Canon PowerShot A2300 it is also necessary to remove the front cover.
            Open the A/V Out Digital port cover on the function button side to reveal a screw.
            Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
            Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
            Gently lift the bottom of the front cover to roughly a 30 degree angle.
            Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
            Hold the camera in your hands with both thumbs on the screen with the screen faced up.
            Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
            Pry the top off by sliding the spudger under the On/Off button.
            Slide the cover to the right and off the camera.
How to share in photo camera to mobile
How to share photos camera to mobile
