The Cannon PowerShot A1000 IS is a compact digital camera. This guide gives instructions to remove and reattach the plastic casing when attempting internal repairs.
            The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
            Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
            Remove the two fine thread screws on the side of the device, to the right of the camera lens.
            Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
            Remove the one coarse thread screw underneath the battery cover.
            Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
            Gently remove both sides of the casing.
