If your LCD is cracked or not turning on replace it with this guide.
Using the plastic opening tool, pry off the top cover of the LCD assembly.
After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
Gently pull the ribbon cable to remove the LCD completely.
