Canon EOS Rebel XTi Back Cover Replacement
  1. Canon EOS Rebel XTi Back Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
    I have the rebel xti as well, and have the same issue, and i have 2 new primary batteries, and 1 new secondary battery, and 1 new charger, yet the camera, still will not turn on. So, if not the battery or the battery charger, what could be the problem? Ty
    Rich Irons - crwdns2934203:0crwdne2934203:0
    I had no idea my camera had a second battery!
    Terri - crwdns2934203:0crwdne2934203:0
  4. Canon EOS Rebel XTi Back Cover Replacement, Memory Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Back Cover Replacement, Back Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
  8. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
  9. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
  10. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws located in the memory card slot:
    • Two M3x2mm JIS #000 screws
  11. Canon EOS Rebel XTi Back Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry off the back casing.
    • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
    • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
    • Gently pull the ribbon cable out of the connector.
Nicholas Abate
crwdns2935283:008/28/15crwdne2935283:0
656 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-6, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-6, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G6
crwdns2935297:018crwdne2935297:0
This was invaluable - I had to replace the door over the memory card slot. I bought one through Amazon, but had no idea how to do it. Thankfully, this guide and my 64 bit driver kit (which I have used many, many times) made it a ten minute job. Thanks!
hoppergs - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,502
