Removing the casing from the camera is necessary to perform any sort of maintenance to the internals of the camera. Once the case is separated from the camera, make certain to be gentle and disconnect any wire harnesses to avoid damaging any components.
Place the camera upside down, and position it to where the back of the camera is visible.
Pull the orange tab to the right to release the primary battery.
To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
I have the rebel xti as well, and have the same issue, and i have 2 new primary batteries, and 1 new secondary battery, and 1 new charger, yet the camera, still will not turn on. So, if not the battery or the battery charger, what could be the problem? Ty
I had no idea my camera had a second battery!
Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
Slide the memory card door in the direction of the arrow engraved on the camera.
Once the door has slid open to its full position, lift up on the door.
With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
Remove the following screws located in the memory card slot:
Two M3x2mm JIS #000 screws
Gently pry off the back casing.
Use a spudger to lift the tab on the ribbon cable's ZIF connector.
Gently pull the ribbon cable out of the connector.
crwdns2935229:05crwdne2935229:0
This was invaluable - I had to replace the door over the memory card slot. I bought one through Amazon, but had no idea how to do it. Thankfully, this guide and my 64 bit driver kit (which I have used many, many times) made it a ten minute job. Thanks!
