Canon EOS Rebel XSi Daughter Board Replacement
  1. Canon EOS Rebel XSi Daughter Board Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Daughter Board Replacement, Front Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
    Removing the top is missing from the guide, not hard tho, remove each screw next to the strap attachment points.
    Then disconnect the Ribbon Cable and black connector from the motherboard, as well as the yellow and pinkish-red plugs from the daughter board.
    Snap Second - crwdns2934203:0crwdne2934203:0
  14. Canon EOS Rebel XSi Daughter Board Replacement, Daughter Board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screwdriver head, remove the three 3mm screws
  15. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the cable from its plastic base with fingers
  16. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide board out with thumb
  17. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect cable by pulling out from plastic base with fingers
  18. Canon EOS Rebel XSi Daughter Board Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect cables by pulling out from base with fingers
Erik Mork
crwdns2935283:001/27/17crwdne2935283:0
617 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 22-10, Maness Winter 2017 crwdns2935289:0Cal Poly, Team 22-10, Maness Winter 2017crwdne2935289:0
CPSU-MANESS-W17S22G10
crwdns2942667:0crwdne2942667:0 1,451
