This replacement guide shows how to remove the device's daughter board, also known as the mother board extension located on the front side of the camera. The front panel must be removed before hand.
Squeeze the eyepiece between your index finger and thumb and lift up and off.
Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
Remove the side panel by lifting off with fingers.
Using the PH000 screwdriver head, remove the four 3mm screws on the front
Remove front grip by gently peeling from the edge towards the center of the camera
Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
Using the PH000 screwdriver head, remove the three 3mm screws
Carefully remove the cable from its plastic base with fingers
Gently disconnect cable by pulling out from plastic base with fingers
Disconnect cables by pulling out from base with fingers
