Canon EOS Rebel XS Grip Replacement
  1. Canon EOS Rebel XS Grip Replacement, Latch Side Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Grip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Grip Replacement, Disassembling Canon EOS Rebel XS Front Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Grip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Grip Replacement, Grip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Canon EOS Rebel XS Grip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingertip to pry off the external shutter port cover.
  7. Canon EOS Rebel XS Grip Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Canon EOS Rebel XS Grip Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS Grip Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon EOS Rebel XS Grip Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Canon EOS Rebel XS Grip Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the grip is loose, use your fingers to remove it from the camera.
Daniel Bussone
crwdns2935283:001/28/11crwdne2935283:0
1,260 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 3-41, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 3-41, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S3G41
crwdns2935297:021crwdne2935297:0
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,749
